Thread: Intermatic Valve Actuator
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    If the actuator is mounted vertical, can water enter through the back where it mounts to valve, and into the actuator?
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    Oct 2014
    Villa Park, CA
    52
    Re: Intermatic Valve Actuator
    Both the Jandy and Intermatic actuators have 3 O-rings on the shaft according to their manuals. I think they are made by the same factory. The Jandy manual says:
    The JVA has three seals which should be lubricated once a year. One o-ring is located on the bottom of the actuator where the plastic shaft exits the housing and two (2) O-rings located in the top cover near where the shaft exits the top of the housing.
    I have one of my 3 actuators mounted vertically and never had a problem with water intrusion, but I live in SoCal and don't get that much rain.
    20' x 40' 30,000 gallon IG Plaster with Spa, wading pool, fountain built 1993
    Pentair 011018 IntelliFlo / 2HP fountain pump / 2 HP spa jet punp / Jandy Ji8000 controller with IntelliComm II interface to IntelliFlo
    Crystal Water Aqua Clean 60 Sq ft DE filter / FlowVis Flow / Stenner DIY Chlorinator / The Poolcleaner 4-wheel / Taylor K-2006
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Thanks, here in Florida plenty of rain, i thought it might be the cover gasket, but that looks fine its only 3 months old. There is not alot of water, could also be lubricant running down...
    Autopilot SWG
