Thread: Spare set of cartridge filters to swap out & clean, good idea?
    Jun 2015
    Oldham, KY
    8
    I have been told I need to use pool filter cleaner and soak my four C7470 cartridge filters for 12-16 hours in the cleaning solution. I am thinking about ordering 4 new ones, replacing the original 4 and cleaning them then storing those 4 to use next time I have to clean. Just rotate each set of 4 every time I need to clean the filters. Here are the 4 I'd liek to purchase and swap out with the 4 that are in the filter.
    Amazon.com : 4) NEW UNICEL C-7470 Replacement Swimming Pool Filter FC1976 PCC80 For Pentair : Swimming Pool Cartridge Filters : Patio, Lawn Garden
    Are there any issues with removing and storing cartridge filters that have seen some use and then reusing them?
    In ground fiberglass 26000 gallons. Pentair Intelliflo VS+SVRS pump, Autopilot SWCG w/ Pool Pilot Digital Nano, Polaris 280V vacuum with booster pump. AquaCal SQR166 Super Quiet Icebreaker reverse cycle heat pump.
    Jun 2015
    Oldham, KY
    8
    Re: Spare set of cartridge filters to swap out & clean, good idea?
    BY the way, how do you most safely, environmentally dispose of filter cleaner water?
    Donldson's Avatar
    NW Ohio
    2,896
    There is no problem rotating different sets of filters, except making sure to store them where mice can't turn them in to nests (personal experience talking). That said, who is telling you that your filter needs deep cleaned and why? Either way, if you do feel like you need to clean it then here are some instructions chem geek wrote about when and how to clean a filter: Re: How to clean a cartridge filter
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jul 2015
    Tempe, Az
    123
    Bob - you can also use dawn dishwashing detergeant. Soak the filters for a couple hours in a garbage can, flip, repeat, rinse. There's nothing environmentally damaging in either - you can dump the dirty water right on your lawn and let it naturally recycle. Even if you throw in TSP, that won't hurt the lawn either (it's actually good for your grass!)
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Trisodium phosphate (TSP) can also be used to clean them and its environmentally friendly. Thats a good plan to have an extra set if you ask me.
    Divin Dave,
