Results 1 to 9 of 9
Thread: Storing chemicals
    Jul 2015
    Cape May Court House, NJ
    121
    Storing chemicals
    I thought I had a good idea, but now I'm not so sure. We put a small shed out behind the pool for the pump/filter/plumbing (everything except the heater) and storage (pool toys, extra chairs, etc.). At that time I had no intention of doing my own water maintenance, but now I'm totally on that path. So, I figured the shed would be perfect for storing chemicals and supplies.
    We've now had a string of hot, sunny days, and I've noticed that it's even hotter inside the shed. I put a digital thermometer in there today and this afternoon it reads 105. I'm thinking it may not be a good idea to put some of my chemicals in there.
    Here's what I've got:
    - liquid chlorine in a 2.5 gal refillable container from the pool store
    - a gallon jug of muriatic acid
    - part of a bag of calcium chloride flakes
    - some boxes of baking soda
    - a box of 20 Mule Team Borax
    - a box of Arm and Hammer Washing Soda
    - a TF-100 test kit
    Right now the only thing on that list that's been in the hot shed is the chlorine, which I'm taking out today. Any thoughts on the other stuff? What's stable, what's volatile, and what would break down or spoil?
    22K 16'x40' inground fiberglass pool, Hayward Pro Series High Rate Sand filter, Hayward dual speed 2 hp Super II Pump, Hayward AquaRite SWG, Raypak 400K btu propane heater, Dolphin Supreme M400 cleaning robot, CoverPool auto cover. Also stand-alone Sundance Hawthorne 430 gallon hot tub.
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Re: Storing chemicals
    Im sure others will jump in but as a newbie Id keep all liquids & the test kit in a cooler place.
    I keep my test kit in our laundry room which is off our den which is where i do my testing
    Liquid Chlorine & MA in the garage
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,631
    Keep your acid away from chlorine and ALL things metal.
    Jun 2014
    15,192
    Boy, can I relate to what Woody just said. I made the fatal mistake of storing acid in my shed with shelving and 4 bikes. Duhh! Now I keep the acid in a Rubbermaid container in the shade outside away from everything. All other chemicals and test kit I keep in our laundry room like any other given day - of course with more bleach.
    Aug 2014
    Shallotte, NC
    693
    MA bottles are made to outgas... AND as others have noted, it will rust or corrode everything it can reach. ALSO, chemicals and test reagents should NOT be kept in the same space....
    Jul 2015
    121
    Wow, this all REALLY good to know! Just by luck, I've had the chlorine in the outside shed, the MA and the dry chems in the garage, and the test kit in a cabinet on my deck in the shade. My MA bottle is now out of the garage (away from the new car!) in a very well-ventilated and shady area, and the chlorine is is outside in the shade quite a ways away. BTW, my MA bottle just looks like an ordinary 1-gallon jug, similar to a bleach jug. I don't see anything about it that would allow it to outgas.
    Jun 2014
    15,192
    Yeah, that MA is a sneaky bugger. Keep it far away until you need it and you'll be happier for it. Make sure the test kit is in a controlled environment too. Not sure how hot it gets under your deck shade, but mine is still an oven. Woo! I keep my reagents in the A/C.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Summary
    Muriatic acid outside in shady place
    Bleach/chlorine inside laundry room or pantry preferred or garage
    Test kit inside in air conditioning
    Dry stuff like CYA anywhere
    Jul 2015
    121
    Just brought my test kit inside in the AC. Thanks!
