Results 1 to 7 of 7
Thread: Concrete boat?
    Jun 2015
    N Tonawanda, NY
    480
    Concrete boat?
    This is going to be an expensive fix.
    http://wfla.com/2015/08/03/pool-pops...ound-in-pasco/
    16' x 34' vinyl in ground - 16,500 gal.
    Hayward EC-75 DE filter with Hayward 1hp Super Pump
    TF-100XL Test Kit with SpeedStir
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: Concrete boat?
    Oh, boy
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: Concrete boat?
    Never, Never, Never drain more then 50% unless you're very sure about your water table. You don't want this to happen to you!!
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    Re: Concrete boat?
    yup. Its history. Insurance won't cover that either. It will cost probably 20K to demolish it, haul it off, and fill up the hole.
    Then after that, fix the porch.
    Its a shame. Too bad they didnt know about TFP before they pumped it dry.
    Divin Dave,
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Re: Concrete boat?
    Im assuming that the pool was empty also, BUT the article doesn't say it was empty and also said Pasco County has been hit hard by heavy rain recently. Some areas were under an evacuation order on Monday. Could there have been any circumstances where the pool had water in it, was pushed up, cracked, water started to leak out making it lighter so got pushed up more etc...?
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Re: Concrete boat?
    Did you see the photos/video? looks like there is hardly any water in it.
    what a disaster.
    Dolphin E10 Cleaning Robot.
    Jul 2012
    Central Texas
    436
    Re: Concrete boat?
    Could have been avoided also by drilling sump holes through the bottom. Pools looks small enough to that 2 should have done it.
    Central TX / 12K GAL / IG / SWG / DE filter / Pentair SVRS & 3 swim jet pumps / Spa bench and jets / Single body of water / No heater.
