Results 1 to 7 of 7
Thread: Sand filter gauge replacement
    Jul 2015
    Eaton Rapids
    41
    So I'm finally getting around to replace my broken pressure gauge on my sand filter but I've run into an issue... getting the old one off. It doesn't appear to turn at all and I don't want to break anything else.
    I'm attaching some pictures in the hopes that someone might have an idea.
    I also don't know what kind of sand filter it is (it was given to me by the same person who game me the pool) so I was also hoping maybe someone would recognize it and could point me in the right direction for what kind of gauge I should buy.
    Thanks!
    7600 gallons AG. Hayward Sand filter. Taylor k-2006.
    22,553
    Re: Sand filter gauge replacement
    It will screw off. In the first picture you see a square metal area just behind the gauge dial. You can out a wrench on that and turn it counter clockwise looking at the top of the gauge (Right to left in the picture).
    Aug 2015
    Buffalo, USA
    1
    I am new to a pool to but looks as if it is a Jacuzzi sand filter.
    lefty51's Avatar
    May 2015
    East of Royals country western MO
    451
    Hello and welcome to TFP,
    The nut you see on the back of the gauge, where it threads into top of filter. Put a wrench on that and turn counter clockwise, it might be tight at first, but should come loose. If you have to put a 5 foot cheater bar on it, then stop !
    Seriously though it should, it should break loose and unscrew from filter.
    If you haven't already bought a replacement, I recommend the one that TFtestkit sells, It's the perfect gauge and priced right. As far as brand of filter, I'll leave that to more knowledgeable people to answer.
    Hope that helps. Let us know how it comes out.
    Don't forget to put a little pipe thread on the replacement gauge
    Si -central Mo. 32' x 16' -- 3'4" to 6' deep Vinyl liner - 16,500 Gals : Triton II filter -Duraglass 2 hp pump - 1 speed : SI-30 salt generator
    TF-100 with speedstir
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    What Lefty said
    I just got a new gauge from TFtestkit's when i ordered some regents, It's much better quality the the old gauge it replaced, it's bigger as well as is glycerin-filled.
    TFTestkits.net
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Jul 2015
    Eaton Rapids
    41
    Quote Originally Posted by lefty51 View Post
    Thanks so much! Quick question before I do this, will I need to put the filter to "close" or anything like that?
    lefty51's Avatar
    May 2015
    451
    No, just make sure pump isn't running at the time, it would be like plugging a dike
