Thread: SLAM Complete, Now Have Questions About SWG
    john.esher's Avatar
    Jul 2015
    Havertown, PA
    40
    Now that my water is clear, the OCLT yields a .4 overnight drop and there's no CC, I have a question about pump/SWG timing.
    Reading Pool School - Water Balance for SWGs I find that I should run the pump during the day. I'll start with 4 hours and check my FC level after sundown to determine if it's keeping up.
    I get about 50% direct sun coverage during the day. What would be the best time to run it: morning or afternoon?
    Intex 18' x 52" AG with Sand Filter Pump & SWG (Model ECO15110) about 7,600 gallons tested with a K-2006-SALT.
    lefty51's Avatar
    May 2015
    East of Royals country western MO
    451
    Re: SLAM Complete, Now Have Questions About SWG
    I think running it during the day, when sunlight and bather load is using up chlorine. But as others will tell you, it also depends on whether your electric rates are higher during daylight peak times. If they are that might be a consideration.
    As far as how long to let pump run, if you can keep pool clear at 4 hours by bumping up SWG, that would be better than lowering SWG and running pump longer. IMO.
    Si -central Mo. 32' x 16' -- 3'4" to 6' deep Vinyl liner - 16,500 Gals : Triton II filter -Duraglass 2 hp pump - 1 speed : SI-30 salt generator
    TF-100 with speedstir
    30,427
    Lefty nails it......IF you can keep the pool clear on 4 hours run time. Many can but many have pools that are too active and need more filtration.
    john.esher's Avatar
    Jul 2015
    Havertown, PA
    40
    So this morning I was at 8.4 ppm of FC. Twelve hours later (sunny day about 90') I'm at 7.2 ppm. So I lost about 1.2 ppm with a pump run time of 6 hours. I'll increase it to 7 tomorrow morning and see how I do.
