Thread: Copper staining
    Aug 2015
    Indianapolis, Indiana
    1
    Copper staining
    Copper staining issues. I have a in ground fiber glass pool that holds 7000 gallons. I can remove the stain using Stain Out product which works great. I vac the pool out after about an hour or so circulation. Then a I add a bottle of Metal Free to the pool, this is recommended from a pool chemical supplier. Pool looks great once this all complete. Stain returns two to three days later. I am dumping a lot of $$$ that I dont have that kind of $$ to wasting. We did add a heater this year, but i have had this issue in the past, but once I have done the above steps, It is gone. What can I do to the copper out. My chemicals PH & Chlorine levels are low right now. Please help.
    Jun 2014
    15,189
    Re: Copper staining
    Hello and welcome to TFP! Some questions that may help us better serve you first:
    - How do you know it's copper staining? Has the water been tested?
    - Are you on a well or have you used algaecides in the past?
    - What test kit are you using (TF-100 or Taylor K-2006)
    - Can you post your readings: FC, CC, CYA, PH, TA, and CH?
    - What are your pool specifics (type, equip, etc) Please add to your signature.
    Many of these questions will help us to help you. Welcome to TFP!
