Thread: Pool Newbie - What equipment to turn off (and how) - before cleaning salt cell
    Aug 2015
    Lewisville, tx
    5
    Hi - I am a pool newbie - just bought a house with a 15K gal pool - with SWG.
    I saw some green algae on the steps the first day. Took the water to Leslie's for a test.
    Results -
    FC - 0
    TC - 0
    Salt 3800
    CH - 180
    CYA - 15
    TA - 120
    pH - 8.0
    The first day I put Muriatic Acid and let the filter run for 4 hrs.
    Next day added pool shock 2 bags (chlor brite). Thats when I saw that the AquaRite unit was set to off. Turned it on - that was yesterday.
    Brushed quite a bit. The algae seems to be lighter.
    Today checked the unit again - and the salt is at 1800, check salt is red and inspect cell is orange.
    I ordered my TF 100 strips today. So cannot test myself for a couple days. Will take the water again to Leslie's tomorrow.
    I dont want to add salt yet - because the salt in original reading was correct.
    I read up on how to clean the salt cell and I am comfortable opening the T-Cell and cleaning it.
    The part I am not sure of is how to turn the unit off. What all needs to eb done.
    Do I turn the filter off. Aquarite unit off. Then the switch (there is one near the pool equipment).
    Then take the salt cell cord out?
    I am still trying to understand all this equipment (there ae lot of levers and I am not sure if I should be touching any of these at this time).
    Tried Youtube videos - most say - turn off the unit - not sure what all..).
    Any help is appreciated..
    Thanks!
    15K Gal, InGround, Jandy Pool System, AquaRite SWG, Plaster
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Pool Newbie - What equipment to turn off (and how) - before cleaning salt cell
    There should be a circuit breaker that will cut power to the SWG. Turn it off. And turn off the pump so you don't shoot water everywhere when you take out the cell.
    Aug 2015
    Lewisville, tx
    5
    Thanks.
    So - I will check tomorrow which breaker turns power off for SWG. What is the general location for these breakers - with the rest of the circuit breaker in the house, or close to the pool.
    I didn't see any apparent near the pool. I will check again.
    And when you say - turn off the pump - you mean filter pump, right?
    DFW, TX
    24,497
    Yes, filter pump. There should be an electric panel near the equipment pad to shut off all equipment there.
