Thread: Sinking AG pool
    Dtaylor113's Avatar
    Jul 2015
    Dumas, AR
    22
    Sinking AG pool
    The poles on one side of our metal frame pool is sinking into the ground. We have a soft yard after it rains and that is when we notice the sinking. We have attempted fixing it several times but the rain always causes sinking. Are we right in thinking the yard just won't support a pool? Is there a solution to this?
    24ftx50in 13,500 gal Summer Escapes AG, stock one speed pump w/ cartridge filters
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Sinking AG pool
    Have you put pavers under the posts?
    Dtaylor113's Avatar
    Jul 2015
    Dumas, AR
    22
    Re: Sinking AG pool
    Yes they sink too. Like the weight of the metal posts pushes them down.
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    Re: Sinking AG pool
    Do you have any pics of your pool so we can see how bad the sinking is.
    6280 Gal Intex 17' x 52" Metal Frame AG
    2500 GPH Filter Pump
    Intex Krystal clear SWG
    Taylor K-2005 With FAS-DPD Drop TEST KIT And Speedstir
    Intex Robot Pool Cleaner
    DFW, TX
    24,485
    Re: Sinking AG pool
    Wow, that is pretty soft. Since it is only a few you could get a hand tamper and tamp it. Add fill and tamp until it firms up. Are you using 12" pavers?
    It is also possible that the pool is on a fill area. Sometimes builders will dig a hole to throw site debris, trees, etc and bury it.
    Aug 2015
    Bloomville, OH
    3
    Re: Sinking AG pool
    Stone under neath your pavers......if it were me, I would use at LEAST 12' pavers and stone under the pavers.
