Thread: Hubbs - Pool Fool in Toronto
    Aug 2015
    Near Toronto, Ontario
    1
    Cool Hubbs - Pool Fool in Toronto
    Hi Folks. I've been lurking this finding this forum in the spring and using the info to bring my green water back to sparkling crystal clear. I've got a older vinyl lined 20x40 foot, 37K gallon pool. I'll be looking to begin replacing components over the next couple of years. I had a solar heating system this spring. Next I think is replacing the pump with a variable speed to get more energy efficient and a new gas heater as solar alone doesn't cut it this far north.
    Nothing urgent but hoping to learn and share info.
    ... Allen
    Aug 2014
    Northern IL
    4,615
    Re: Hubbs - Pool Fool in Toronto
    I also have a 20x40 pool, but my volume is significantly less than yours. Was that a typo?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Welcome to TFP!
    At the bottom of Poolmath is a pool volume calculator. 20x40x7' avg depth is 37k gallons.
    More here on adding your pool info to your sig, Pool School - Getting Started
    Aug 2014
    Northern IL
    4,615
    That would be a deep pool!!! Welcome to non-lurking status!
    Casey's Avatar
    SW PA
    10,438
    Welcome to TFP! We offer a wealth of information if you so choose to soak it up.
