Thread: Which backwash valve/o rings to order?
    Sep 2014
    Los Angeles CA
    40
    Hi, have a pentair filter, water is leaking out of the backwash and I think it is an issue with the push pull backwash valve. Unfortunately I'm not sure what type of valve/orings to get. AMazon has a couple that look identical. The valve is just sitting there with no obvious way to tell which type it is.
    Here is some pics in case that helps.
    DSC00308 | Flickr - Photo Sharing!
    DSC00307 | Flickr - Photo Sharing!
    can I just get something that looks similar or am I going to have to be precise?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Which backwash valve/o rings to order?
    Go to the pentair website and download the manual for your filter. In the back is an exploded parts diagram that will have the part number and info.
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    The pentair website is the best place to find that info
    6280 Gal Intex 17' x 52" Metal Frame AG
    2500 GPH Filter Pump
    Intex Krystal clear SWG
    Taylor K-2005 With FAS-DPD Drop TEST KIT And Speedstir
    Intex Robot Pool Cleaner
