Thread: Heater crapping out, should I try and fix or replace???
    Jul 2015
    Atlanta, GA
    11
    TFP'ers,
    I just bought the house with pool/spa and it has a Jandy LITE2 heater. The first day, it heated up the spa great. Since then, it will only heat up to about 94 degrees. Some photos here: https://goo.gl/photos/hKm9CKKw9spLkotNA.
    Any ideas on whether this is something that can be fixed, or should I look to replace it all together? If replace, any recommendations on a heater that would fit into same area and with same pipes?
    Thanks!
    McLovin
    McLovin
    12,500 gal, In ground, salt water, gunite/pebble, Jandy CL580 pool/spa filter, aqua pure PLC1400, Jandy LITE 2 heater, Aqualink RS
    Aug 2013
    Arab, Alabama
    422
    Re: Heater crapping out, should I try and fix or replace???
    Hello! I would post this question in the Everything Else forum. They have an expert that knows about heaters and he will be able to answer all of your questions. I have the same heater but have not used it since buying our house.
    39YO 13K gallon former SWAMP/MONEY PIT, concrete bottom/Fiberglass Walls, Ecotech VS pump, Hayward Sand Filter, Dolphin DX5 Plus, Loop-Loc safety cover and YES, I have a TFT-100 test kit!
    Shock Level and Maintain - CL/CYA Chart
    Jul 2015
    Atlanta, GA
    11
    Thanks - will do.
    McLovin
