Thread: Like new Dolphin Z5 - Good deal?
    JamieP's Avatar
    May 2011
    Waxahachie, TX (south of Dallas)
    1,135
    I found a guy selling a like new Dolphin Z5 that he says has only been used 8 times in 2 weeks for $850. He has the receipt from epicpoolsupply which he says can be used to get the warranty, but I'm not sure how that would work. He has a vinyl pool that he says the robot doesn't work well in and that's why he's selling it. I can go to his house and see that it functions properly in his pool before I buy it. It comes with everything it was originally shipped with -- caddy, remote, cleaner, receipt and warranty card.
    Do you think this is a good deal? I'm a little concerned about the warranty, but maybe I can still get it. Please let me know what you think. I don't want this to get away if it's as good of a deal as it seems like. Thanks!
    28,000 gallon freeform, Stonescapes Tropics Blue Minipebble with abalone, 3.5' to 8.5' depth. 2 skimmers, 5 returns, dedicated vacuum port, Dolphin Z5 robot. All Pentair equip: EasyTouch 8, IC60 SWG, VS pump, 520 Cartridge Filter, 3 Intellibrites, 2 Color Cascade Bubblers. TurboTwister Slide and 8' Salt System Jump Board. TF-100. My Jan-Mar 2016 build:
    Waxahachie, TX Owner Build - A race to beat the baby!!
    Feb 2015
    Chandler AZ
    926
    Re: Like new Dolphin Z5 - Good deal?
    You may want to have a quick read of the warranty terms.....
    http://dolphinpoolbot.com/warranty.php
    That being reviewed, you may want to contact them and see if they will allow a warranty transfer, since it's only a few weeks old and it won't work in the sellers vinyl pool.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    JamieP's Avatar
    May 2011
    1,135
    Thank you. I was looking for that type of information, but couldn't find it. I'll have to call the company in the morning. Without the warranty, it doesn't seem like as good of a deal.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I think it is, and would encourage you to jump on it. Make it an issue and offer 650-700. Get it for 800 and it's still a good deal.
    Essential Links:
    JamieP's Avatar
    May 2011
    1,135
    After talking with Maytronics on the phone and confirming that I could get the warranty on this unit, my husband and I went and bought it today. The guy showed us how it worked, and considering his vinyl liner pool had algae, we got to see it leave "clean" tracks across the pool floor. But now the sponges on the rollers are green with algae and I want to make sure I deal with them properly before I store this thing until our pool is built. We rinsed them off which helped a little, but there is still residual green in them. Is it right to assume that if they dry completely the algae will die and when I use it in our new pool it won't cause any trouble?
    Also, since this pool of ours won't be built until the fall or winter, what is the recommended way to store this thing? Do I need to worry about it sitting on the rollers all that time? We have the caddy, if that helps.
    Feb 2015
    Chandler AZ
    926
    Good deal - especially that Maytronics will honor the warranty. Always worth contacting the manufacturer, worst they can say is no.
    As for the greenish rollers, maybe clean them in a bleach/water mixture - say 25% household bleach and 75% water. Remember to rinse really well with fresh water when done. No need for them to rot out while you wait a few months to be able to use it.
    I would think storing it in the caddy would keep the rollers from getting flat spots from direct surface contact while sitting for extended periods - but not entirely sure, as I dont have this unit. Set it in the caddy and see if the rollers still make firm contact - if not, you're good to go.
    Gene
