Thread: Difference between pentair spabrite & aqualight
    May 2015
    Grapevine, TX
    4
    I have a Pentair light in my spa taking on water. Series is 7810XX, 100 watts, 120v.
    Pentair makes several models and I cannot tell what the differences are. If I go with a 7810 series, (Spabrite, I believe) it's more money than the 7711 series (Aqualite).
    Is there a size difference?
    Note: I'm going to drop an LED replacement bulb into this, so the quality of the bulb it comes with doesn't matter.
    Thanks!
    Glenn
    25k in-ground
    PebbleFina w/ Spa
    Jandy RS-8
    Polaris w/ separate pump
    Waterfall, separate pump
    Casey's Avatar
    SW PA
    10,423
    Re: Difference between pentair spabrite & aqualight
    I am unsure on the differences but someone may know.
