Thread: Should I call the local hazmat department?? - don't be an idiot like me
    Dec 2011
    Prosper, Texas
    124
    So most of the summer I have been fighting with keeping my chlorine levels in check. I was always having low numbers so I added additional time to my Stenner pump. It got to the point where I was running the pump 8 hours a day. (I have the 3 gallon per day model). So yes a gallon of bleach a day. Much more than I needed last year.
    I even went as far as to shut the Stenner pump off and SLAM the pool as I thought I was fighting an algae bloom. I only had to slam it for 3 days which I thought was odd. I was traveling quite a bit during the summer so I just kept making sure the tank was full before I would leave but each time I would return to little or no chlorine in the pool. It was very frustrating.
    I was going to be out of town for 12 days so I asked a neighbor to refill my 15 gallon tank after I was gone for a week. I had a full tank and 9 jugs of bleach next to my tank for him to use to refill it, which he did. I also cranked up the time on the pump to 12 hours a day (1.5 gallons a day). I got home and had no chlorine in the pool!!! I then noticed something. All of my gravel around my equipment pad was white. it was very odd. I unscrewed the line from the Stenner pump where it enters the pool plumbing and nothing was coming out, now i had tested this earlier in the summer and some was flowing (but probably not enough...). I then unscrewed it on the pump side and there was a steady flow of bleach. I checked the line and it looks like a rabbit or something had chewed it in a couple places, or maybe it just cracked for some reason. I fixed the line and am happy to report by the next morning my pool was back up to proper chlorine level using just the pump.
    I would guess over the summer I have dumped between 30-45 gallons of bleach on the side of my house.... Don't be an idiot like me, keep your lines off the ground and check them often. I was going crazy and was about to just go back to pucks....
    Pics or it never happened...
    21,000 gallon pool w/spa, Pebble Sheen, Hayward EcoStar variable speed filter pump, Hayward DE6020 Filter, Hayward 400FDN Heater, Stenner pump with 15 gallon tank, Clear O3 ozone system, Hayward Goldline PS-8 controller, Hayward 6060 cleaner pump, Polaris 280 cleaner, Hayward EcoStar variable speed water feature pump.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Should I call the local hazmat department?? - don't be an idiot like me
    But it appears they have bleached out to a nice pretty white.......
    Glad you found it.
    I'm lucky, all my pool equipment is in a 12 foot tall "crawl space" under my house and it sits,on a nice concrete floor. If a leak appears I'm sure I will find it and no critters to chew on the tubes. Whoever was chewing on it probably got a mouth full of bleach when they finally chewed through
    Support the site
    Jun 2014
    15,008
    That's one way to whiten your teeth.
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    On the positive side, you won't have any spiders, ants, rodents, or any other vermin getting into your house through that wall!
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    At this point, it's just salt left. Not especially hazardous.
