Results 1 to 7 of 7
Thread: New, Orange Pool...
    Aug 2015
    new castle / Indiana
    1
    New, Orange Pool...
    Hello All!
    We have a new Intex 22 X 54 pool filled with well water and just as many others have experienced its now rust orange. Hoping to get some idea of what to do since following direction of the local pool store prior to finding this wealth of info on TFP.
    Highlights:
    Day 1 cocktail:
    ~ 2lb HTH Super Shock (Saturday)
    ~ 2 3" Chlorine tablets floating about
    Pool Store Testing Day 2:
    CYA 0
    pH 7.5
    Fc 6.7
    Alk 242
    Hardness 354
    Copper 0.1
    Iron 0.4
    Added based on recommendations:
    1/3 gal Muriatic acid to lower alkalinity
    16oz Stainrine for metals
    So far I have been flushing out the filter roughly every 3-4 hours during the day and the water appears to becoming lighter in color, slowly.
    From studying pool school I need to raise my CYA to ~30, I will be picking up some stabilizer after some more research on TFP recommendation.
    The question I have is my water went from brown while filling to rust orange color, will the chemicals I have in now clear up the water, slowly over time? Or is there another option...
    Jun 2014
    14,970
    Re: New, Orange Pool...
    A couple things:
    #1 - Welcome to TFP!
    #2 - You should take a look at this page: Pool School - Metals in the Water and Metal Stains. Understand that once metals are in yoru water or supply source, it's just something you have to learn to manage.
    #3 - Pool store testing? No good. Please see these two links for the proper test kit:
    TFTestkits.net
    Pool School - Test Kits Compared
    Here are some other links you will use quite often:
    Pool School - Chlorine / CYA Chart
    Poolmath calculator
    Welcome, and let us know if you have any more questions.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,181
    Richard always has such good,quotes, I'll throw one in here.
    Try the search function for rust or iron.
    Some people have had good luck putting layers of paper towels in the skimmer basket to trap the rust particles. Someone else recently made some sort of prefilter using pillow batting in a bucket. The more you can remove physically as rust particles, the less you'll have to deal with chemically.
    Support the site
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Welcome!
    A couple threads I recall. Check out the pictures.
    Results of first TF-100 test ran on fill water
    A Tale of Two Filters... and Ugly, Rusty Water.
    High FC high pH and filter it out with pillow batting or paper towels. Then use sequestrant on the residual
    May 2014
    Franklin, NC
    9,181
    Darn, Richard caught me using his words.....
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Orange handed! LOL!
    Casey's Avatar
    SW PA
    10,421
    Welcome to TFP. How's the pool coming along?
