Thread: Raypak 2100 heater (fuse?)
    Aug 2015
    OKC/OK
    2
    I replaced our pool pump motor, once everything was good to go, I flipped the breaker back on. I heard a pop from the heater and now no longer has power.The pump motor is working fine. The heater had been working fine in limited use this past spring. Any ideas?
    Jun 2012
    western NY
    1,559
    Re: Raypak 2100 heater (fuse?)
    I am sure we can help.
    what did you change in the wiring?
    Is the pump and the heater on the same circuit?
    Is there any wiring connection between the heater and the pump?
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Aug 2015
    OKC/OK
    2
    No change in wiring,.. Not on same circuit and no connection between heater a pump.
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Sounds like maybe the transformer blew. Can you check for power coming in and out of the transformer?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
