Thread: Backwash Valve Broken - Need Help!
    Apr 2015
    Flower Mound, TX
    11
    Hello,
    I have a Hayward backwash valve that was stuck due to a broken O-ring. when Trying to pull up the handle to clean and replace the o-rings my handle snapped off and the rest of the valve is firmly stuck in the pipe.
    the handle broke off right at the first top seal.
    Any help on how I can remove rest so I can replace it? Thanks!
    Alex Miller
    Motor - 1HP centurion (B852 built in 2007)
    Pump - 1HP Whisperflo WF-24
    Filter - 120 gpm, 60 square foot Hayward DE
    Booster Pump - Centurion 3/4HP
    Cleaner - Polaris 360 Vacuum
    Casey's Avatar
    SW PA
    10,438
    Re: Backwash Valve Broken - Need Help!
    Oh ghesh Alex... What a bummer. I don't own a sand filter but I know someone here should know how to do this.
