After the fill, I just kept track of the CYA based on how much dichlor was added and when we were in the area I wanted (35) I did the drop test for CYA and it was right about there (filled the tube all the way up before the black dot disappeared). I am due to use dichlor this week for the once a month "make up for lost CYA" but maybe I'll test the CYA and see where it's at. Possibly it has gotten lower and needs to be bumped back up. I hate to actually do that test each week because of it using 7ml of the solution each time but clearly it's worth it.
Tho I feel like the rate of FC use was high even when we had sky high CYA (before you taught me about how dichlor adds and adds and then the FC has to be higher because of it).
