Results 1 to 13 of 13
Thread: To Shock or not to Shock
    Aug 2015
    Grants Pass, OR
    17
    Hello,
    Roguewave, here. 10 year lurker, first time poster. There is no doubt in my mind that this is the best place on the web for pool care advice and I appreciate all I've learned from many of you over the years.
    Forgive the long post, but consider some of it my introduction.
    The basics:
    20,000 gallon, 16x32 vinyl lined, in-ground, diving pool.
    9 Fafco panels and a Compool controller. Our pool season generally runs April 1st through the end of October and we're in it almost every day we're home.
    Taylor K2006C
    Currently using trichlor pucks until CYA rises to where I want it for a given season and then bleach.
    This morning's parameters:
    CYA - 60
    Cl - 5.5
    pH - 7.5
    Al - 90 (added 38 oz of baking soda this morning)
    CA - 80 (here at TFP I learned not to concern myself much with CA for this vinyl pool)
    CC < 0.5
    Haven't had to shock to lower CC yet this year. The cover is normally off all day, which probably helps (according to this site.)
    On the advice of the pool installer, I installed an ecomatic SWG when the pool was new about 10 years ago. Well... the cell had a long life, but finally gave up the ghost a couple of years ago. Now since ecomatic has gone the way of the Dodo, I looked into aftermarket cells and the reviews of their quality were pretty awful.
    So... without the budget to replace the ecomatic entirely, I was forced to switch to the old standard approach.
    I keep my parameters tight. Alkalinity never gets beyond 90 or 110. pH almost never off by more than 0.1, Keep chlorine about 1 ppm above the minimum recommendation as per The Pool Calculator. Haven't had any algae blooms in what seems like forever.
    We have a week-long, family trip planned in the next month and, rather than run the pump, I plan to leave the cover on and bump up the chlorine with enough liquid bleach to hold 'er 'til we get back (erring on the side of caution, of course.)
    I estimate the minimum to be about 4 bottles of 8% (or 7?) Walmart concentrate. So I would probably do 6. With the cover on and a CYA of 60, I believe it's likely we will be coming home to a pool that will need a few days with the cover off.
    According to chem geek's chart, I estimate I need about 10 bottles, total, to shock.
    Using the K2006C, I get < 0.5 CC when using a 10 ml sample. The reagent does turn it a hair pink and one drop returns it to clear. But the funny thing is, when I use the 25 ml mark, I can't get the sample to return to pink no matter how much reagent I use.
    This is puzzling, but I feel it's OK to figure that I don't have much CC.
    So... my question is...
    Would it be worth it to go ahead and shock... figuring that I would probably have to add some thiosulfate upon our return?
    Or would just a moderately elevated level of chlorine finish oxidizing what little CC I have?
    Or?
    Jun 2014
    15,268
    Re: To SLAM or not to SLAM
    If I'm reading all of this correctly, your big issue is that you're prepping for vacation and don't want the FC to drop too much while you're away correct? If that's true, why not wait on the pucks. Use the bleach now. Take it to SLAM/Shock level with bleach again just before you leave, put the pucks in at that time, then cover. Or am I missing part of the equation.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    If you go to shock level and cover the pool, odds are you will return to a clear pool that still has some FC remaining.
    Since it's safe to swim up to shock level, and there's no way the FC level will climb during the time you are away, you shouldn't need thiosulphate at all. All you need to do upon return is test the pH, FC, and CC. If FC is less than 10, the pH reading is reliable. If FC is above 10, leave the cover off and wait a day. If CC is above .5, wait a day. If it's still there, SLAM it.
    Aug 2015
    Grants Pass, OR
    17
    Re: To Shock or not to Shock
    ...Since it's safe to swim up to shock level...
    Looks like the answer came in an unexpected form. Another day at TFP, another lesson learned.
    Shock it is!
    Thanks!
    P.S. Subject heading edited for accuracy
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Welcome to TFP.
    What country is Jefferson state in? Location and climate is an important factor when we help you with your pool. Please update your location and add your pool info to your signature, more here, Pool School - Getting Started
    Richard320's Avatar
    Jan 2010
    19,074
    Quote Originally Posted by pooldv View Post
    Welcome to TFP.
    It's okay. I know where it is. Far Northern California
    DFW, TX
    24,514
    What? CA is its own country now with states? LOL
    Aug 2015
    Grants Pass, OR
    17
    Yes... and Southern Oregon. Climate is all pretty much the same in the Great State of Jefferson. Zone 7. Decent springs and falls. Hot, dry summers and cold, wet winters.
    Our benevolent overlord, Big Brother Google, knows all...
    https://www.google.com/#q=jefferson+state
    Fafco panels & Compool controller. Pool season +/- 4/1-10/31
    Trichlor pucks until CYA rises to where I want it for a given season, then liquid bleach.
    Sand Filter
    Taylor K2006C
    Richard320's Avatar
    Jan 2010
    19,074
    Quote Originally Posted by Roguewave View Post
    I didn't need google. I know a lot of California history and geography as a transplanted Northern Californian.
    Aug 2015
    Grants Pass, OR
    17
    Sorry. That was intended more for pooldv or anyone interested.
    Much like Central/Northern Cal would like to break off from Southern Cal... the far north of California would like to break away ALMOST as much as many Southern Oregonians would like to break away from Portland down through Eugene. And if it weren't for WWII... it just might have happened.
    But we digress...
    Good thing you answered the primary question for this thread already... 'cuz we're gettin' a little off topic.
    Sand Filter
    Taylor K2006C
    DFW, TX
    24,514
    LOL! That is true, but trying to read and respond to hundreds of threads per day doesn't leave a lot of time to stop to google locations. Although, I am curious about what Jefferson State is, so I might go google that just for fun. Northern CA would be pretty helpful.
    30,432
    +1 what pooldv said. If OP had posted a question on closing (or opening) Jefferson State would have told me nothing about his climate and I would have simply gone on to something else.
    Aug 2015
    Grants Pass, OR
    17
    Well fortunately I didn't ask a question that really hinged on climate this time, but... I can see how important this is.
    Profile updated.
    Thanks again for the help. Bought more liquid bleach today.
    Have a nice evening
    Sand Filter
    Taylor K2006C
