Thread: Which robot??
    MGood's Avatar
    May 2015
    Eldridge Iowa
    67
    Which robot??
    I'm looking at all the options and reviews but not sure what would be best since I've never owned a pool before. They are gonna dig this week, so I thought I better get this ordered. Our pool will be a 20x44x30 with a 6x20 sun deck and underliner steps. Looking at the Dolphin oasis Z5 but really don't want to spend that much if possible. We are lucky because we don't have any close trees, so leaves will only be an issue in the fall when they blow from the neighbors. Suggestions please. Thanks!!
    20x44x30 L shape Only Alpha with 6' sun deck with 2 bubblers, 350k heater, 1 1/2 HP and SWG. Dolphin Nautilus Plus. Estimated construction start time is beginning of Aug.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Which robot??
    I've heard great reviews recently here on TFP about the Nautilus and new Nautilus plus. Would be worth looking into those two as well.
    Isolated Spa - 345 Gallons
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Re: Which robot??
    I have a dolphin Nautilus, and its a very good economically priced basic robot. It will randomly climb the walls and clean a little bit of water line each time it does. It does a fantastic job of keeping the whole floor clean and will pick up small to medium size leaves.
    This is my second season with it, and no problems at all.
    Divin Dave,
