Thread: Jacuzzi jets adjustment - please advise
    Sep 2014
    Ottawa, Ontario, Canada
    18
    I would like to adjust eyeballs of my two Jacuzzi jets in order to change flow direction. The attached pictures show both the pool and one of the jets.
    I am not able to move the eyeballs by using a pipe inserted into the opening or by vise grips - even if I loosen the 3 screws. The pool and the jets are of 1968 vintage and as a result the eyeballs may be simply frozen.
    • Any tip on how to move the eyeballs?
    • Or should I replace the jets?
    Thank you.
    Attachment 41127
    Attachment 41128
    21K gal, IG plaster new 2010, 3/4 HP Super Pump with 2-speed AO Smith motor w/integrated 2Green timer, sand filter S-244T2, solar heating with HM-4000D controller, Dolphin M400 pool cleaner.
    Casey's Avatar
    SW PA
    10,461
    Re: Jacuzzi jets adjustment - please advise
    Well, that's a good question. They may need replaced if they are very, very old. Lets see if someone else can chime in.
    P.S. Beautiful pool!
