Results 1 to 8 of 8
Thread: Is there any harm in keeping your chlorine higher then need for your CYA level?
    Jul 2014
    NJ
    46
    My Chlorine is between 25-30 so I know I only need to keep my chlorine at a 4, but a couple of weeks ago I had algae, which I DONT want again (and I really didn't think my chorine level was down). We are having a few events the next couple of weeks, so I want my pool in pristine condition. Is there any harm in always keeping my pool chlorine level at 6? I don't mind "wasting bleach" so besides that is there any harm in aiming high?
    5,700 gallon, Carribean Isle 15x52 Round Above Pool.
    Cartridge Filter.
    Installed Fall, 2014.
    North New Jersey
    Using the TF100 test
    Jul 2015
    Coventry, CT
    22
    Re: Is there any harm in keeping your chlorine higher then need for your CYA level?
    Hello. Definitely will need your other test numbers. Specifically your CYA. But I am curious as to the answer to your question too about keeping FC higher then "needed".
    24' AG (still learning details)
    1.5hp pump
    Clear Water High Rate Sand Filter 22"
    Jun 2014
    15,189
    I think in your opening statement you meant to say your "CYA" is between 25-30 right? But basically, if you're wondering about maintaining FC at 2-3 ppm higher than your target, based on your current CYA, that's fine. Actually that can be a good proactive measure that won't hurt a thing, especially in areas with lots of sun or pool activity.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    That's no problem as long as it's below slam level. I usually keep mine a couple ppm above what it needs to be just for safety's sake in case I don't get out to check it.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Jul 2014
    NJ
    46
    Yes, I apologize I meant my CYA is between 25-30. Thank you. Good, I am going to keep it a little higher, I feel "safer" that way!
    Cartridge Filter.
    North New Jersey
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    It won't hurt the pool any, but it may get rough on swimsuits.
    Fear of overstabilization is good, but I'd raise the CYA closer to 40. It's easier to read it and it will provide extra buffering and more sun protection. A couple 8 oz trichlor pucks in a floater will do the trick, if you have any laying around.
    Jul 2014
    NJ
    46
    Great thanks, I am going on vacation in 2 weeks so I plan on using the pucks when I am away, so didn't want to raise CYA, and then have the pucks raise it more when I am away
    Cartridge Filter.
    North New Jersey
    Richard320's Avatar
    Jan 2010
    19,037
    Quote Originally Posted by marianegs View Post
    Perfect!
