Thread: Above ground - replacing plastic joint pins with Steel (or Stainless steel hardware)
    Jul 2014
    Lexington, NC
    106
    Would it be a good idea to replace the plastic joint pins with a nut and bolt? I'm pretty sure stainless steel hardware is out of my price range but even with the wear and rust on regular hardware I think it would last longer than these plastic pins. Any thoughts? Anyone ever done this?
    15'x45" AGP Metal Frame with SWG Intex 2500GHP - Hayward SP1091LX Dyna-Skim Above-Ground Pool Skimmer and Accessory Kit - TF 100
    Jul 2014
    Oakbank, Canada
    389
    Re: Above ground - replacing plastic joint pins with Steel (or Stainless steel hardwa
    Seen a few pictures of it done, and stainless hardware is not overly expensive. More than regular of course, but not huge. Go to a industrial supply warehouse, they will be cheaper than big box store for sure.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
