Thread: hth liquid chlorinator
    rubone74's Avatar
    Jun 2015
    29
    Hello, guys and gals!
    Recently purchased a couple boxes of HTH liquid chlorinator at the Walmart because they were $6 a box. Box read 10% Sodium Hypochlorite. Is there any difference between this brand and the others I can buy at the local Leslie's or Champion pool stores? The reason I ask is because I spoke to a couple of fellow pool owners who explained the other 90% of inert ingredients contained in the cheaper brands may contain higher amounts of salt or calcium than premium brands. Is this something I need to be concerned or aware of? Where can I find the MSDS or the list of ingredients for the other 90%? Thanks for any info!
    Ruben
    13K gal, inground, pebble, 3HP Pentair Intellipro VS pump, Sta-Rite System 3 cartridge filter, A&A infloor cleaning system, Taylor K2006 test kit. Build date 06/15.
    domct203's Avatar
    Jun 2015
    CT
    3,577
    Re: hth liquid chlorinator
    Quote Originally Posted by rubone74 View Post
    Ruben
    http://www.noblegov.com/media/catalo...ds/N463C48.pdf
    First hit from a Google search
    https://www.google.com/search?q=HTH+...lorinator+MSDS
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    rubone74's Avatar
    Jun 2015
    29
    So, basically water and salt! Is this pretty much the same makeup as other brand liquid chlorinators? Thanks for the info!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Yes, liquid chlorine, liquid shock and bleach are all sodium hypochlorite, water and a pinch of salt. The only difference is the percentage of sodium hypochlorite.
    Jun 2015
    N Tonawanda, NY
    469
    I also found the HTH to be a pretty good buy. 128 oz. @ 10% vs 121 oz. @ 8.5% for most of the bleaches.
    16' x 34' vinyl in ground - 16,500 gal.
    Hayward EC-75 DE filter with Hayward 1hp Super Pump
    TF-100XL Test Kit with SpeedStir
    rubone74's Avatar
    Jun 2015
    29
    Awesome, thanks for all the help! I'm going to dump some in my pool right now!!
