Thread: Is that impeller broken?
    Jun 2015
    Holon
    4
    Hello everyone.
    My intex sand filter pump is making allot of noise. so after a quick search i found that intex bearings are of poor quality and need replacement so im taking care of that.
    However, when i checked the noisy pump i also noticed a licking from the impeller area. when i took the pump apart for the bearings i noticed there is a metal part with some rubber at the back of the impeller with a spring and i cant tell whether its broken or suppose to be like that. also the impeller is rotating off centric. can anyone tell me if its suppose to look like that or whether its broken?
    here is the back of the impeller:
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Is that impeller broken?
    That is the shaft seal.
    Jun 2015
    Holon
    4
    Quote Originally Posted by bobodaclown View Post
    yes but is it broken? should you be able to see the spring?
    May 2008
    Northern California
    71
    Yes, that is normal. You can see another picture at Step 16 here:
    How To Replace a Pool Motor Shaft Seal - INYOPools.com
    12,000 gal. IG Colorquartz, 1.65hp Sta-Rite with 2-spd motor, 300sf cartridge, disabled SWG, AquaLogic P4, Polaris 280, gas+solar, 6' sheer descent with dedicated pump
