Thread: Celebrating my one-year anniversary with TFP!
    Jul 2014
    Bakersfield, CA
    1
    I found the TFP website a year ago. I'd taken over care of my pool after using a pool service for three years. I had the pool painted so the pool had been drained and refilled and I took over the care of the pool and had to learn everything from scratch. I went to Leslie's and bought a few hundred dollars worth of supplies and followed their advice. I took in water samples often that first summer and used their kit for testing of Cl, pH, and TA. During the winter, I stopped taking in samples and the water looked fine, following the advice of how many pucks to add each week. At the beginning of the next summer I took in a sample and was shocked to hear that the Cyanuric acid level was over 100. I asked, How did that happen? That's when I learned that the pucks (and shock) I'd been adding raised the CYA level. I asked what I should do about it. Well, I needed at least a partial drain but should wait until winter. What was I supposed to do in the meantime? Use more pucks, of course! Run two floaters full of pucks instead of one! I knew that was bad advice that would only keep raising the CYA level. So I searched the internet for an alternative and found the TFP website. What a lifesaver! I became educated in the TFP method of pool chemicals. It all made sense and it worked! I became a TFP supporter. I managed to keep the water clear until I could do a partial drain in the winter. Since then I have added borates. I am so grateful for the TFP website. You guys rock!
    18,000 gallon inground, painted plaster
    Pentair 3/4 hp pump, cartridge filters
    2nd Pentair pump for waterfall/slide
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: Celebrating my one-year anniversary with TFP!
    Woohoo! Congrats!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    First year, first post, that's pretty cool. Welcome to the forum from out of the lurker shadows.
    Essential Links:
    Casey's Avatar
    SW PA
    10,457
    Welcome to TFP!
    lefty51's Avatar
    May 2015
    East of Royals country western MO
    451
    Well we're glad your here and congratulate you.
    Now for the bad (?) news. You won't be getting a congrats card from the pool store
    Si -central Mo. 32' x 16' -- 3'4" to 6' deep Vinyl liner - 16,500 Gals : Triton II filter -Duraglass 2 hp pump - 1 speed : SI-30 salt generator
    TF-100 with speedstir
