Thread: BBB and CYA
    chezhed's Avatar
    Mar 2009
    Mission, TX
    37
    BBB and CYA
    So I've tested everything as follows
    FC 2
    CC .5
    TA 110
    pH 7.6
    CYA 55
    CH 260...I think, it's close...I had a hard time counting that high with my shoes on
    So what's the BBB answer to raise CYA to 70? I'm adding bleach to increase FC and muriatic acid to lower pH to then aerate and decrease TA...but what to do about CYA?
    11,000 gal + overflow spa, IG gunnite, Pentair 48FNS DE filter, Hayward SP3210X15 pump, CompuPool CPSC36 Chlorine generator, pool valet w/5 zones, Pentair LP heater
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: BBB and CYA
    Just add some CYA to the skimmer or use trichlor or dichlor if you have any.
    I like to put the CYA in a sock in the skimmer so it dissolves before entering the filter in case I have to backwash my sand filter. Just be sure to wait a full week before retesting CYA.
    chezhed's Avatar
    Mar 2009
    Mission, TX
    37
    Re: BBB and CYA
    Forgot to ask...do I really need to raise the CYA? My pool does not get a lot of direct sunlight and my chlorine (OTO testing only) last summer remained very steady in its first year.
    30,431
    Re: BBB and CYA
    No, but why wouldn't you? Almost all SWG manufactures like to see 60-80ppm. It'll allow you to run your FC a little lower and, subsequently, increase your cell life.
    That said, it sounds like you have your pool sorta' "in the zone" and you know how to keep it there. With that in mind, I might opt to stay just where you are.
    Guest
    Re: BBB and CYA
    Quote Originally Posted by chezhed
    Read this thread and it might answer that question for you!
    water-balance-tips-for-a-swg-t3663.html
