Results 1 to 13 of 13
Thread: Pool Math Question
    madgreen's Avatar
    Jul 2015
    Hurricane/Utah
    12
    Pool Math Question
    I am a new gunite pool owner and was looking through the pool math chart. My pool builder has me using sodium hypochlorite 10% for chlorine. I don't see that chemical on the chart for choices. Any ideas on what I use on the calculator? Any help is appreciated. My test kit is basic, of only chlorine and PH, but I am getting a better kit to use to test the other items such as CH, TA etc.
    Madgreen from southern Utah
    13,700 gal, IG Plaster, Pentair 1 1/2 HP pump, cartridge filter, SWG (waiting 1 month, new pool) 7-23-15 built, filled w/city water Test Kit-Taylor K-2006
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Pool Math Question
    Welcome!
    Sodium Hypochlorite is bleach. Just plug 10% in for the strength instead of the default.
    Someone else from Hurricane just joined a few weeks ago.
    Mar 2015
    Georgia
    157
    In the FC row (yellow row) over to the right change the "6" to a "10" and you got it. It will say "10 trade"
    Add of % bleach. Jug size 96 oz.
    16k AG Vinyl Sand Filter
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Welcome to TFP!
    Well, I can assume he has you using a liquid - Sodium hypochlorite is the fancy scientific name for chlorine/bleach. The stuff you use for you washing machine "bleach" comes in multiple concentrations, but generally you can find it on the label, like 6% or 8.5%.
    It's stronger cousin is called chlorinating liquid and generally comes in higher % such as 10% or 12.5%. It may be labeled as pool shock, shock, liquid shock or something like that. Many time this is sold in reusable containers called carboys. As there is no label, you need to ask what the strength is.
    Wow, three of us were,typing an answer at the same time!
    Support the site
    madgreen's Avatar
    Jul 2015
    Hurricane/Utah
    12
    thanks so much for all the help
    So one can use just standard household bleach? Just pay attention to the strength?
    Jun 2014
    15,221
    Yep! Generic is fine as well. Just make sure it's regular. No scents, no splash-less stuff. Good-ole common household bleach. Also watch the Julian date on the container. Some stores try to sell old stuff that may be losing its strength.
    madgreen's Avatar
    Jul 2015
    Hurricane/Utah
    12
    Does it matter that I started off with 10% and then if I want I can buy just standard household bleach, just know the % of the product?
    thanks
    Jun 2014
    15,221
    Doesn't matter at all. Just make sure if you're using the Poolmath calculator to modify the % block so your numbers come-out right.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Any percentage is interchangeable at any time. They are all chemically the same, just different percentage.
    Richard320's Avatar
    Jan 2010
    19,051
    Quote Originally Posted by madgreen View Post
    thanks
    Yep. Many people do the math and figure out the cost per percent-ounce and buy whatever's cheapest. Sometimes it works out that the 12.5% from the pool store is the best bang for the buck, sometimes it's a sale at the grocery store.
    A tip: if they're ashamed to post the strength, you don't want it.
    madgreen's Avatar
    Jul 2015
    Hurricane/Utah
    12
    Is there a reasonable place to buy bleach and muriatic acid that you know of? Thanks for all the help. A great place to learn information.
    Jun 2014
    15,221
    Many of us get generic bleach from places like Wal-Mart or the common grocery store. Muriatic acid can be found at the pool store, home improvement store, etc. Someone who is from Utah may have even more specific ideas.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,009
    bleach at any supermarket, Walmart, costco, etc..
    Muriatic at Home Depot, Lowes in the paint department. Ace Harware stores and others I cant remember the name of .
    Muriatic Acid comes in 2 strenghts. 31.45 and about 14.5 ish. The low strength stuff is also called "green" because of the low strength and usually cost just as much or more than the strong Muriatic Acid. Stay away from teh "green" stuff. Get the strong stuff, as that is the best bang for the buck.
    FInally, a PB who recommends using the right stuff. Very rare anymore these days.
    Divin Dave,
