Thread: Adding DE with leaking backwash
    Sep 2014
    Los Angeles CA
    40
    hi, so water is leaking out through the backwash, I suppose through the valve. I don't have time to do a replacement job at the moment so would it still be okay to add DE to the filter or would that eventually all go into the backwash as well?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,007
    Re: Adding DE with leaking backwash
    I think it depends on whether the leak is from the input or the output to the waste line. If it's after the filter, you won't see any DE escape. If it's before, you will lose some DE when you add it to the skimmer to recharge.
