Thread: "Inspect Cell" flashing? what is a "cell"
    torontocollegeboy's Avatar
    Jul 2015
    Toronto/ON
    7
    Hi all,
    I'm a newbie to the pool game and I have a question about the SWG "inspect cell"
    I have a SWG with about salt level at 3200, sand filter with my outdoor in-ground pool with about 30k gallons of water. I keep my pump on 24/7.
    A few days ago, I'm seeing that the "inspect cell" light started flashing, I didn't know what it was so I ignore it. However its still flashing. What exactly is a 'cell' and how can I 'inspect' it to get it back to normal?
    Thank you!
    feeding my pool with my textbook money
    Jun 2015
    Ottawa/Ontario
    340
    Re: "Inspect Cell" flashing? what is a "cell"
    How old is your salt system?
    90,000litre, IG vinyl, 1/2 HP Tristar pump, Sandfilter, Aquarite T-15 ASG
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    If it's an AquaRite, the flashing "check cell" light is just a timed reminder to check the salt cell for scale buildup. The cell is inline an should have a number like T-15. You clear the light by pushing the diagnostic button until the light goes out.
    The cell has unions that allow it to be removed for service.
    Support the site
    Jul 2015
    Toronto/ON
    7
    I'm not sure how old the unit is actually.
    should I call the pool guys to take it out for service? or is this something that I can take out and clean by myself?
    thanks!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    You can do it. Turn off the power to the SWG and shut off the pump. Unscrew the unions on each side of the SWG cell. Take it out and look inside for calcium scale which looks like white crusty build up.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Don't try to scrape it clean. The plates have a very thin coating that could be damaged.
    chiefwej
