Results 1 to 9 of 9
Thread: Need tricks for removing horizontal bars in an Intex Ultra Frame pool
    Aug 2015
    Canby/OR
    1
    Hi everyone,
    I desperately need help taking down our Intex Ultra Frame Pool. We bought our 12x24x52 pool in June, but had several side supports collapse a few days ago, just past the return date (of course). We've been taking the pool down while we wait for replacement parts (they are out of stock, of course). We can't seem to get the horizontal bars out of the liner sleeve. The liner is stuck to the bar -- it's almost like there is velcro in there. We can loosen the liner in one place, but it sticks in another. We've used compressed air, water under pressure but no luck.
    Any suggestions? I'm thinking of using a silicone spray on the bars when we set it up again, but that doesn't help me now.
    Silver Tiger
    Intex Ultra Frame Pool 12'x24'x52". Salt water filter.
    Jun 2015
    Stockholm, Sweden
    250
    Re: Need tricks for removing horizontal bars in an Intex Ultra Frame pool
    Sorry to hear about your troubles. I just assembled the same pool yesterday, filling it up right now. Do you know what caused the collapse? Makes me a little nervous...
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,520
    Can you twist it inside the liner as you're pulling it out?
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Orlando, FL
    690
    You have to pry the liner away from the bar. I just used my fingers and yes, it is tedious work. However, after you get the first few off, it does get easier. Pry with your finger and lots of wiggling the bar.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    May 2012
    Las Vegas, NV
    92
    having another person assist will help.
    Intex 22' x 52" Ultra Frame - approx 10,000 gallons of water
    Intex Sand Filter pump (8hrs Run Time)
    Krystal Clear Saltwater Model 7110/8110 (6hr run time/day)
    K-2006 TEST KIT
    Jul 2015
    Corona, CA
    16
    Did you get it all taken apart? I was gonna suggest some dish soap diluted in a spray bottle. Maybe all you need is a little surfactant to loosen the grip of the vinyl. Let us know if you got it taken care of.
    18' x 48" Intex AG, 6700g
    1500gph Intex cartridge pump, SWG
    Installed June 2015 w/ city water (on restrictions)
    Taylor FAS-DPD 2006 kit
    Jun 2014
    Uxbridge Ontario
    56
    When I disassembled mine last year the same thing happened.
    I found that simply turning the bar in the sleeve eventually broke it loose.
    They do stick pretty good though!
    Good luck!
    21' x 52" Round Above Ground. (Buried 2') AquaPro 1HP pump, Jacuzzi 19" Sand filter, Hayward inline chlorinator.
    Hayward H200 millivolt NG Heater, SunQuest 2 x 2'x10' Solar heater.
    Oct 2017
    Tucson/Arizona
    2
    We had this problem last year so this year when we set up we slathered talcum powder on the poles. We took it down today and those puppies slid right out. Doesn't help when taking down and screaming now. But good to know for next year.
    Jun 2015
    Round Rock, TX
    5
    I took a hose and loosened em up by spraying water into the sleeves...was still frustrating but a little easier
