Results 1 to 11 of 11
Thread: Salt Level Decreasing, Aeration a Factor?
    john.esher's Avatar
    Jul 2015
    Havertown, PA
    40
    My salinity has decreased today by 200 ppm over the last ten hours, measured this morning and just a few minutes ago. On Friday it was 3,000 and now I'm down to 2,600.
    I have been using muriatic acid over the last two days to lower my TA, and have been aerating all the while with the return jet breaking the surface to raise the pH. So I'm wondering if this is normal due to evaporation?
    (I have my SWG off as I recently started a SLAM, ran out of R-0871, and am in a holding pattern of nightly bleach additions.)
    Intex 18' x 52" AG with Sand Filter Pump & SWG (Model ECO15110) about 7,600 gallons tested with a K-2006-SALT.
    Donldson's Avatar
    NW Ohio
    2,899
    Re: Salt Level Decreasing, Aeration a Factor?
    Salt doesn't evaporate. The only two explanations are testing error (either human or something is messing with your test) or you are losing a LOT of water. Unless you have an autofill then something must be causing a testing error.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    john.esher's Avatar
    Jul 2015
    Havertown, PA
    40
    Quote Originally Posted by Donldson View Post
    No autofill, just a small Intex AG. And in my mind, losing water should not affect the ppm, just the volume in the pool, right? I haven't added any water in the last few days.
    Except, now that I type that, I did add some yesterday, so, duh, pay no attention to this post!
    Jul 2015
    Western NC
    115
    Quote Originally Posted by john.esher View Post
    Another possible explanation would be a salt level of ~2800 ppm and a salt test with an accuracy of 200 ppm (or worse) ?
    23,000 gallons IG gunite, pebble (I think)
    Hayward SP2610X15 1.5 HP Pump, Hayward sand filter
    Mineral Springs SWCG (it's actually Hayward/Goldline), Hayward Goldline T-CELL-15
    Polaris pool cleaner (with booster pump)
    TF-100, SpeedStir, K-1766 Taylor Salt Test, Lamotte Borate test strips
    domct203's Avatar
    Jun 2015
    CT
    3,591
    ........... And in my mind, losing water should not affect the ppm, just the volume in the pool, right?
    Losing water due to evaporation will raise the ppm concentration until you add replacement water.
    Losing water due to splashout/backwash/vacuum to waste will take salt with it. Replacing that water loss will dilute the salt, lowering the ppm concentration.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Salt stays behind during evaporation. Removed during splash out /backwash. My guess test error.
    38,305
    How did you test? That is only one drop in the Taylor test. And most tests and SWG are only good to +/-400ppm anyway.
    john.esher's Avatar
    Jul 2015
    Havertown, PA
    40
    Into 10ml of water I put one drop of the yellow liquid (not in front of the bottles, so I don't know the numbers) and drop and swirl the other.
    Turns to a milky cream color then boom, salmon colored with a lot of things floating.
    Wasn't aware the +/- was so high.
    Apr 2011
    Murrieta, CA
    2,360
    I believe most test kits are that accurate.
    Dec 2009
    Central Massachusetts
    2,690
    ^ This
    Most salt tests are only accurate to +/- 400 as Jason said, and it could vary a little more.
    As long as the generator is happy and making chlorine, its fine.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Mar 2007
    San Rafael, CA USA
    12,082
    If you use the Taylor K-1766 salt test, then using a 10 ml water sample it is +/- 200 ppm but if you use a 25 ml water sample it is +/- 80 ppm in terms of being +/- 1 drop in accuracy. However, overall the test is also limited by accuracy of the concentration of its reagents and your ability to measure volumes accurately and of drop size and all of these result in +/- 10% accuracy so at 3000 ppm that's +/- 300 ppm. For a given test kit, repeatability should be closer to the +/- 1 drop (if you do the test carefully), but absolute accuracy would be closer to the +/- 10%.
