Thread: Addressing Multiple Issues
    Jul 2015
    Clearwater, FL
    83
    With the torrential rains ending, have to address low TA, low CH, and probably low CYA this week. No confusion on how to address each, but is there any problem doing them all at once?
    16K gallon IG exposed aggregate pool with Aquarite SWG T15 cell, Hayward C1750 filter, EcoStar SP3400VSP pump, H400FD pool/spa heater, Polaris PB4-60 booster pump, 280 pressure cleaner, Hayward Super II spa pump and Air Supply Silencer spa blower
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,073
    Re: Addressing Multiple Issues
    Raising TA and CH at the same time will probably lead to cloudiness. It will pass with time.
    The CYA can just be set in the skimmer in a sock and left there. I'd deal with pH, TA, and CH in that order, and let things mix good between additions. Also remember that you'll lose salt if things overflow, so don't neglect that or the SWG may stop generating.
    Jul 2015
    Clearwater, FL
    83
    Thanks, Richard.
    Have TA up to 70 and am working on CH. Added ~5 lbs of Calcium Choloride this morning to bring CH up to 230 this evening. Added another 3 lbs this evening and will measure tomorrow. Pool Math tells me I need just under 12 lbs to bring CH up to 300. I'll probably be cautious in further additions.
