Thread: How to keep the algae out?
    gamerasian's Avatar
    May 2015
    edison/nj
    85
    We got our pool fixed with new liner and new water. Realized that the motor is bad when it was ready to start. Trying to get a new pump or getting this one fixed ( which is taking time). I let my kids jump in it just once as not very confident about adding chlorine in the pool without the pump running. How can I prevent the algae to build up. I try to brush it once a day and manually remove the leaves and other debris from the top with a net. Please advice any more things I can do to keep the pool clean.
    thanks
    24k IG vinyl , new (not any more)pool, new ( not any more) water Hayward super pump and sand filter.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: How to keep the algae out?
    Maintain adequate FC and mix it with a brush or swimmers. It may end up looking like a bathtub after three people have used it, but it will at least be sanitary and algae free.
    gamerasian's Avatar
    May 2015
    edison/nj
    85
    Thanks for the prompt reply..but I didn't understand when you say may look like a bathtub? Also is it ok to keep swimming in it?
    Richard320's Avatar
    Jan 2010
    19,009
    Quote Originally Posted by gamerasian View Post
    You won't be filtering out anything. It will just be sitting there, like dirty bathwater. Assuming you can see the bottom, the pH is okay, and there's adequate FC for your CYA level, it's okay to swim. A couple swimmers will mix the water better than you ever will with a brush. No matter what, you have to keep the FC level up or your pool will turn green, filtering or not.
    gamerasian's Avatar
    May 2015
    edison/nj
    85
    Got it!!! Thanks a bunch
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    Kids=great pool mixers!
    Kim
