Thread: How long till borates?
    Clayswen's Avatar
    Jul 2012
    Dean, Texas
    134
    How long do I need to wait after mini pebble till I can add the borates to the water? Also, should I wait to bring my CH up? It is only 130.
    102 Perimeter Freeform Pool, Rock Waterfall, Jandy Deck Jets, Depth 3'6" - 6', Stonescapes Aqua Blue Mini Pebble, Inpool Table, Rock Salt Decking, Jandy 2.0 Epump, Jandy 580 Cartridge Filter, Polaris 280 with booster pump, Jandy Power Center w/ PDA, Stenner Pump
    A country boy's pool build...Dean, Texas
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: How long till borates?
    Check with the PB first on everything to make sure you do what they want to stay under warranty. Here is an article from Pool School - Start-up New Plaster. Raise the CH to 250 right away.
    Borates should wait until you have your water balanced and under control. Especially TA and PH. More here, Borates - Why and How
    JoyfulNoise's Avatar
    May 2015
    13,247
    Quote Originally Posted by pooldv View Post
    Definitely wait until after the plaster is started up (would be nice if your builder did the bicarbonate startup process) and you have a few months worth of water testing under your belt. I'd even suggest waiting a full a year With your new plaster and all that aeration from the various water features, you're going to spend a lot of time testing the water and learning what your pool needs. You don't want to needlessly complicate the chemistry.
    Matt
