Thread: Replacement bulbs for pool light
    Oct 2013
    Santa Clarita, CA
    12
    So I have a Jandy pool light, and the bulbs need to be replaced. The label says to replace with this bulb which is 65 bucks for 2, and you need 8, so a total of 260 dollars for 8.
    I found these bulbs on Amazon and they seem to be the exact same thing, and it's 23 bucks for 10 of them.
    Am I missing something? Is there a reason that Leslie's has them at 10 times the price? These are just standard MR16 halogen bulbs, right? Or are they? Can someone help?
    17.5K inground plaster pool/spa, Aquapure PLC 1400 SWG, Jandy stealth 1.0 hp pump, 1.5 hp booster pump, Jandy 60 sqft DE filter, 400,000 btu heater, Zodiac MX 8 cleaner
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Replacement bulbs for pool light
    Shocking isn't it - no pun intended. I use different bulbs, bus all I can say is that the pool store was 100% higher than Amazon.
    In addition to the bulbs, do you need new gaskets? Read the owners manual and see what Jandy says.
    Support the site
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    I know on my lights, anytime you open one you need to use a new gasket to reseal it..
    chiefwej
    Jul 2015
    Austin, TX
    24
    I'm ignoring Leslie's markup for anything pool related. They want 4x the price for baking soda.
    What I could not find are a few aspects of the Jandy bulbs. The amazon bulbs you found specify color temperature (2950K, a "soft white"), and specify a flood beam width of 36 degrees. The Jandy/Zodiac parts don't specify either of those, so while they are electrically and physically compatible, it's not clear if they are identical. I did find one website that has "60 degrees" in the part name, but nowhere else was beam angle mentioned.
    Just to tease further, Amazon had a link to another site, 1000bulbs dot com, that has similar lamps for $0.84 each. 3000K, 36 degree beam width (flood), 2000 hours rating. Eight of those is $7.
    Here are 60 degree floods, 5000 hour rating, $2.58/ea: https://www.1000bulbs.com/product/71...-1000446U.html
    If Jandy published more specs on these bulbs there would be an equal comparison.
    If the Jandy bulbs are 60deg floods then those last 60deg floods might be worth a try, but I don't know.
    Brent / 24k gal / 16'x36' IG / Dura Glas II 1.25hp / 55 sqft DE filter / CircuPool Si-45 / TF-100 kit
