Results 1 to 8 of 8
Thread: Help with Suction clog or other issue...?
    Dec 2014
    Edmond, OK
    82
    So...I am getting about half or less of the normal suction from my skimmer basket line. This is also the line that I vacuum and is the only line for the pool as the main drain is capped off. There is another suction line for the spa that is "over-suctioning" and draining whenever I run the pool. This is how I realized I was having a problem also how I know the pump is pumping. That and the pool is turning green cuz I guess it is not getting enough circulation. So I am curious if you guys could share any tips or fixes to troubleshoot a clogged suction line...? Let me know if you need more info.
    Thank you in advancefor your help!
    30,000 gallons, in-ground plaster, well water, Hayward tri-star pump, Pentair Sand Dollar SD80 filter. TF-100 kit
    Jun 2014
    15,198
    Re: Help with Suction clog or other issue...?
    Other than an adjustment (3-way) valve between the two, is there any chance perhaps you simply sucked something into your skimmer line causing a partial obstruction? Just to confirm, is your skimmer basket (clear lid) full of water? Any air or drop in water level?
    Dec 2014
    Edmond, OK
    82
    Yes - I think I did suck something in there while I was vacuuming yesterday. Im wondering how I get it unclogged. Sorry I know I am a novice!
    Yes Skimmer is full of water.
    Jun 2014
    15,198
    If you suspect something got sucked-in from the skimmer, your options are things like:
    - Try to push water from the skimmer basket (pump) side BACK to the pool skimmer (put a rag around the hose to help create a seal for better pressure)
    - Try running a "snake" line through to free-up the clog
    - Some folks may try air pressure if they have that capability
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Yep - backflush it. Kill the pump, open the pump basket and feed a garden hose down the pump inlet. Ideally, you have a drain king bladder, but wrapping it with a rag will also seal it up. Move the valve to full skimmer suction and hold that hose in and have your helper turn on the water and let 'er rip.
    In years past people have discovered small toys jammed in the three-way valves, so if the first attempt doesn't get things, you might want to disassemble the valve and look inside or try backflushing from there to the skimmer.
    Drain King:
    Dec 2014
    Edmond, OK
    82
    Well I just tried rigging it with a rag to no avail. I did see some small particles come back to skimmer line but nothing even remotely big enough to clog. Hmmmmm. I have a pool company coming out tomorrow hopefully they can diagnose and pprescribe a low cost solution.
    Jun 2015
    Wildomar, California
    423
    The Drain King works well. A compressor with a Drain King works really well.
    Dec 2014
    Edmond, OK
    82
    An update - I just went out there and saw bubble coming out of a return jet. It would appear I have some air in the line. Could that caused the reduced suction? How do I troubleshoot this?
    Thanks again for all of the help!!!
