Thread: Block the sun in my yard
    Jun 2015
    Zeeland, MI
    9
    In the summer, when the sun is going down, it shines in a way that pretty much blinds you. Are there any recommendations as to something to use to block the sun while still letting the breeze through? It would have to be mounted vertically.
    Jun 2014
    15,255
    Re: Block the sun in my yard
    I have built a type of wall frame in the past and used lattice in the middle. That worked well for my purposes. At another location, I made a wall frame, but instead of lattice I installed a bamboo-type shade that I could draw up or down when needed.
    Jul 2015
    Tempe, Az
    123
    2 4x4x8 foot tall posts with an inexpensive roll down sunshade from lowes? Or however many you need....unless you can go permanent then get an inexpensive shade sail and mount it at an angle?
    Aug 2015
    Plano, TX
    217
    Curtis- 20k gallon IG gunnite/plaster with hot tub/waterfall and "grotto"
    All Jandy equipment: 60sqft DE filter - 399k btu natural gas heater - Stealth pumps - iAquaLink RS8.
    Polaris 9400 on patrol.
    TF-100 in da house/TFP method in effect: FC=4-6, pH=7.5, TA=80, CH=250, CYA=50, Borate=50, CSI=-0.21
