Thread: Pentair Superflo leaking?
    Aug 2015
    Noble, OK
    1
    Hi, this is my first post here so please bear with me.
    My wife and I just bought a house with a pool that is an absolute swamp. The poor thing sat for about 2 years with no attention. I plan to SLAM it as soon as we finish moving in, but my first problem is that the pump leaks. The pump is a Pentair SuperFlo and it seems to have a leak on the underside about in the middle of the pump. I'm thinking that I need to replace the o-ring in the housing but I thought that I'd check with you guys first to see what you think.
    Thanks for any help!
    -Rus and Shelly
    I/G Rectangle, vinyl lining, 18x40, Approximately 25K gallons
    Pentair Superflo pump, Sand filter
    **Foreclosure home, pool was unattended for 2 years! (As of 8-1-15, the Swamp Thing wouldn't even live in it)
    38,290
    Re: Pentair Superflo leaking?
    Welcome to TFP!!!
    Sounds more like the shaft seal is leaking. You can get a "go-kit" that includes the shaft seal and all the other seals in the pump if you want to start fresh.
