Thread: Vacuum Projector
    Jun 2014
    Kingsland Texas
    9
    Vacuum Projector
    Pentair HiFlow Valve Sight Glass 272550 with vacuum projector
    What does the vacuum projector, which I guess is just a thin round piece of rubber covering 3 holes in the end of the sight glass' do? The only thing I know it does is to leak water when valve is set to vacuum to waste or to rinse. I can remove the sight glass, remove the thin round rubber and put it back in the opposite side out and it seals for maybe 3 days then starts leaking again. Replaced it the whole site glass about 2 wks ago and the new one started leaking after a week. Sure makes a mess of my pump room!
    17,100 gallons in-ground fiberglass pool - Pentair WF-26 WhisperFlo 1.5 hp 2 spd pump - AquaRite Chlorine Generator controls by Goldline and a Turbo Cell T-15 - Pool installed Feb 2007
    38,536
    Re: Vacuum Projector
    I think it just allows air to be sucked in so that the backwash pipe can drain after you turn the valve back to filter.
    Jun 2014
    Kingsland Texas
    9
    Thanks Jason. In that case, there should be no problem in removing the sight glass and plugging the hole which is what I had in mind to stop the mess. Never look at the sight glass anyway as it is in an extremely awkward position to get to.
