Results 1 to 9 of 9
Thread: High TA Low PH ?Low salt
    Jun 2014
    Abilene, TX
    5
    I am having cloudy water and cannot get it clear. These are my calculations this AM:
    FC = 5.5
    PH = 7.2
    TA = 160
    CH = 250
    CYA = 100
    Salt = 2400
    I am using the Taylor Complete FAS-DPD Pool Water Test Kit K-2006 to test. It has been this way for 2 weeks or more. What acid do I need to add to lower TA? I have muratic acid handy. I understand the higher TA raises the PH? Correct? But my PH is staying the same. My chlorine levels are high so i am not running my SWG at present hoping things clear up. Chlorine levels are coming down. TYIA
    6423 gal., AG, 3/4 HP pump, 2330 GPH @ 6PSI with SandPro sand filter Model 4511, Krystal Klear SWG
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: High TA Low PH ?Low salt
    If your pool is cloudy, I would SLAM. Your FC is too low for a CYA of 100. This is likely why pool is cloudy.
    I recommend lowing CYA to at least 50 but more ideally 30 for the slam. You will have to do partial drains and refills to drop CYA.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Donldson's Avatar
    NW Ohio
    2,881
    If your pH is holding steady then you do not need to mess with your TA. TA does not cause water quality issues, it only buffers pH changes. With your pH at 7.2 you most certainly do not want to add any acid.
    Your FC level is ok for your CYA, I wouldn't let it drop any more. Your CYA level is a bit high, even for an SWG pool. Is there a reason you have it that high? Also are you sure that it is only 100 and not higher?
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jun 2014
    Abilene, TX
    5
    I am not sure why it is high. I went out of town one weekend and my pool turned green. I poured bleach in and boosted my SWG several times and I think I overdid the chlorine. I also added baking soda because my stabilizer was low. Maybe I added too much? What causes your CYA to be high?
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Quote Originally Posted by selmore2725 View Post
    Too much stabilizer raises your CYA.
    Not sure why you added baking soda for low stablizer?
    Please read
    Lisa
    Jun 2014
    Abilene, TX
    5
    Thank you!
    30,403
    Welcome to the forum. I second the suggestion to read "ABC's" up in Pool School. It'll get some basics under your belt and you'll be ready to go.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Thank you!
    Your welcome.
    Lisa
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    One more page to read that is very helpful, Pool School - Recommended Pool Chemicals
