Results 1 to 11 of 11
Thread: Cloudy water
    Baker's Avatar
    Jun 2015
    Ky
    6
    Cloudy water
    How do I get rid off this water I slammed it and the bottom is clean but the pool still a little cloudy.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Re: Cloudy water
    Welcome to TfP!
    A SLAM is a process that is not stopped until the water is clear, not a one time addition of massive amounts of chlorine.
    What test kit are you using?
    Can you give a a full set of test results?
    Support the site
    Jun 2014
    15,212
    Re: Cloudy water
    Welcome to TFP! We're going to need a little more info from you to answer that one:
    - What are your current test readings from your TF-100 or Taylor K-2006? (FC, CC, CYA, PH, TA, and CH)
    - Have you been following the TFP SLAM page; if so, how long?
    - Are you familiar with the 3 criteria to pass a SLAM?
    - What chemicals have you been using?
    - What are your pool characteristics? Please add your pool info to your signature by going to the top of the TFP web page (just under the Pool School button) and select "SETTINGS". On the next page look to the left for a menu bar that says, “MY SETTINGS” and go to "EDIT SIGNATURE" to enter your pool and equipment info there. It will help us later.
    Baker's Avatar
    Jun 2015
    Ky
    6
    Re: Cloudy water
    Quote Originally Posted by tim5055 View Post
    Welcome to TfP!
    No but everything is high new to this
    May 2014
    Franklin, NC
    9,193
    Re: Cloudy water
    Quote Originally Posted by Baker View Post
    Do you have a test kit?
    Support the site
    Baker's Avatar
    Jun 2015
    Ky
    6
    Re: Cloudy water
    Yes it has strips made by clorox
    May 2014
    Franklin, NC
    9,193
    Re: Cloudy water
    Test strips are generally inaccurate and we do not trust the results they give.
    Before I make more recommendations, give us some details about your pool. Type, size, filter ect. The recommendations we give will be different for a 30,000 gallon in ground plaster pool than a 5,000 gallon above ground seasonal pool.
    Support the site
    Casey's Avatar
    SW PA
    10,453
    Re: Cloudy water
    You can't use strips when being serious about pool care and water clarity. Look at the link in my signature for the 2 recommended test kits that will get you past this. The TF100 is the best kit for the money. You need to look at this as an investment to your pool. If not then You will always be guessing with mediocre results.
    Baker's Avatar
    Jun 2015
    Ky
    6
    Re: Cloudy water
    Pool 22 by 53 intex above ground 10k gallons type B filter I think pump 2500 gpm
    Baker's Avatar
    Jun 2015
    Ky
    6
    Re: Cloudy water
    Quote Originally Posted by Casey View Post
    OK thx will look into it thx again.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Cloudy water
    Welcome to TFP!
    A little reading for you to get you going in the right direction.
    Pool School - Getting Started
    Pool School - Test Kits Compared
    Pool School - SLAM - Shock Level And Maintain
