Thread: No cutoff valves to pump
    Aug 2015
    Odenville, Alabama
    2
    I have an above ground swimming pool, I need to work on the pump but I have no shutoff valve on the hose that is connected to the skimmer, what's the best way to keep the water from going into the hose so I can remove the pump, besides draining it of course. Also correct me if I'm wrong, on the filter side of the pump I believe to keep water from coming from the sand filter I just need the valve setting to closed
    Jun 2014
    15,187
    Re: No cutoff valves to pump
    Hello and welcome to TFP. To ensure we give you an accurate reply, can you tell us what type of pump/skimmer set-up you have? (i.e., Intex AG pool, Intex pump, in-wall or over-hanging skimmer, model/make of filter etc). Anything to help give us a picture of what you are dealing with. Thanks.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,404
    If you have the standard hard sided above ground pool with 1 1/2" hoses you can buy a couple of 1 1/2" threaded plugs. Turn off the pump, unscrew the return eye and screw in a plug, then on the skimmer you remove the basket and screw in the other plug. If you don't have threaded openings you can use 1 1/2" expanding plugs from the hardware store. Threaded plugs are available at pool or hardware stores.
    Yes, you can also use the closed or winterized setting on the multiport valve to stop water flowing back through the return.
    Love TFP? Become a
    TFP Supporter!
    wjr75's Avatar
    Jun 2013
    IL
    836
    When you pull off the hose from the pump put it over the rail back in the pool and secure it some how. Change the pump setting as indicated above. I also forgot to note to put your vacumm plate in with the hose out of the water to slow the water coming out of the pump hose when disconnected.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Aug 2015
    Odenville, Alabama
    2
    Quote Originally Posted by wjr75 View Post
    Thanks this helped a lot, the expandable plug worked great too
