Results 1 to 7 of 7
Thread: Cheaper alternative for an Ice bin
    Aug 2011
    Weston, FL (Miami/Ft Lauderdale suburbs)
    25
    Has any one considered using an actual cooler for a Bar top drop in? Something like the picture below, which you can get from Amazon for about $150 (supposedly made out of SS) Minus handles, legs and opener.
    Actual drop in ice bins are probably 3-4x more expensive and about half the size.
    I can see framing around it and having your countertop (eg. Granite) cut out around the top, maybe add some SS trim for looks (and to hide any silicone/sealant needed so as to prevent water to enter through the gaps between cooler and countertop)
    They also usually have threaded drains so coupling to a pipe can easily be done too.
    Completely crazy idea?
    In construction (well, it is really permitted and we are waiting on PB to start digging, long story): 86 LF free form gunite, sundeck bubbler, jets on swimout. Hayward automation, pump (2-speed) and 40K gallon SWS
    In design: 20' ODK not idea what is going to look like yet
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Re: Cheaper alternative for an Ice bin
    Sounds like a good plan to me.
    Love TFP? Become a
    TFP Supporter!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Couldn't you just use a stainless steel sink and insulate it with aerosol styrofoam, or enclose it with extruded foam sheets and fill the gaps with the aerosol foam? Plumbing the drain would be a snap and scrubbing it out would be easy.
    Ice chests tend to get stinky after a while, and I've tossed more than a few that ended up somehow swelling and deforming internally.
    Aug 2011
    25
    Richard that's a good alternative my wife suggested it as well, I think the issue would be available volume because of depth limitations (too shallow) and because of the curved bottom.
    Having said that, the stink issue could be a real problem.
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Great idea.
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    Livermore, CA
    32
    I seriously considered using this sink - 32 Inch Undermount Deep Single Bowl with some extra insulation and a homemade HDPE lid as a drop in cooler. In the end I realized I didn't have the counterspace available, but I wound up using it for my sink anyway.
    I figure if I ever need to I can dump a bunch of ice in there, and if I wind up doing that a lot I'll insulate underneath (although it is already rubber coated).
    Honestly, so much of the stuff that's sold specifically for BBQ islands is ridiculously overpriced. $700 for a 15" sink? Really??? You're much better off doing something creative and saving yourself some $$.
    Darren
    ~20K gallon freeform w/attached spa
    Pentair 4x160 pump
    Pentair Mastertemp 400K BTU heater
    Intellitouch i7+3 controller
    Intellichlor IC40
    May 2012
    Montville NJ
    545
    While not quite the same, I took a regular ol plastic Coleman cooler, removed the handles and hinges, and built a weathered wood (old cedar fence comes in handy) enclosure and hinged top around it. It sits on the pool deck. It works great. Using the one you want in a countertop would be even easier, because you lid would be left exposed. I had to finegale the hinge points on mine to make sure it opened and closed corectly.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
