Thread: Calcium Hardness Results... Should I be alarmed
    Jan 2012
    Mission, TX
    16
    Tested my pool water today and pool chemistry was: FC 5, PH 7.5, TA 80, CYA 70, CH 800., water temp 90. Pool water seems to look good. Was in the process of debating whether or not to add borates to 30-50 ppm to control ph drift due to SWG. My wife is concerned about health hazards. If I decide to proceed with adding borate I was going to increase to 30 ppm. Outdoor Pool is in direct sunlight almost all day.
    12,000 Gallon IG Saltwater, Blue Quartz/Glass Bead Plaster, Pentair Quad 80 Cart Filter, A&A Infloor Cleaning System, Pentair IC60 SWG, EASY Touch Control Panel with 4Button Wireless Remote, Pentair Inteliflo VS, Pentair Ultra-Temp 120 Heat Pump, FLOWVIS Check Valve & Flow Meter 2"
    30,431
    Re: Calcium Hardness Results... Should I be alarmed
    What is the CH of your fill water?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,512
    You can let your TA drop as low as 50 to see if that will stabilize PH first. Keep adding acid to lower Ph and TA will drop.
    I am a fan of borates, more here, Borates - Why and How
    Jan 2012
    Mission, TX
    16
    CH of my fill water is 300
