Results 1 to 7 of 7
Thread: Pool is full, First Set of Numbers are in, What do I do?
    Jul 2015
    Charter Oak, California
    273
    Question Pool is full, First Set of Numbers are in, What do I do?
    Just finished filling my pool about 5:00 PM PST and have my first test results with Taylor K-2006. How do I proceede.
    FC- 2 ppm ( after this reading I added 24 oz 10% based on how I ubderstood the Taylor Tables..OK?)
    PH- 8 ppm
    ALK- 140 ppm
    CH- 170 ppm
    CYA- No reading (could not hide the black dot)
    Do the numbers look good? Tested several times until I got consistant numbers..
    Purchased 10% Chlorine and Stabilizer in preperation for the initial fill on the advice of TFP response to my frist thread..
    Pump has been running 4 hours.. What's next.....
    Bob (AKA Schnozz)
    12 x 24 x 52 Intex Ultra Frame AGP, 8600 Gal; Pentair 2HP/2SP 150sqft Cartridge Filter; Hayward Through Wall Skimmer; Intex Automatic Cleaner (Fantastic); K-2006 Test Kit; Start-up 07/30/2015. First Time Pool Owner in SoCal.
    30,431
    Re: Pool is full, First Set of Numbers are in, What do I do?
    What does your water look like?
    Jul 2015
    273
    Crystal Clear...
    Bob (AKA Schnozz)
    Jun 2014
    15,205
    First thing you want to do is get some stabilizer in their ASAP to protect your chlorine (FC). Use the sock method to suspend granular stabilizer near a return jet until it dissolves. Remember it will take about a week to show-up on your readings.
    Until the CYA builds to at least 30 (you may go higher based on sun in your area.), always use the Pool School - Chlorine / CYA Chart to keep your FC at or slightly higher than the target that matches your CYA. That is extremely important for sanitation and preventing algae. You will need to check 2-3 times a day until the CYA builds.
    Use acid (30 minutes apart from any bleach additions) to lower your PH to the mid-7s.
    Always refer to these to add chemicals based on your pool:
    Poolmath calculator
    Remember, pump stays on for 30 minutes after adding chemicals to mix good, and never add acid and bleach together.
    Good luck!
    30,431
    Crystal Clear...
    Simply bring your parameters within the suggested guidelines. read "The ABC's of Pool Water Chemistry" up in Pool School......it has suggested levels and tells you how to move them up or down.
    Jul 2015
    273
    Numbers still all pretty consistent. As of tonight at 6:00 PM PST:
    FC: 3.5 (10% Liquid chlorine)
    PH: 7.7
    TA: 150
    CYA: <30
    Crystal Clear
    I've been adding between 22 & 33 oz chlorine each night to maintain a FC of 3.0 to 3.5 by 6:00 pm every night. Added two pounds stabilizer first week on recommendations from last post. Added one more pound tonight and I'll check the numbers again next Friday. Is there any concern that the TA is so high?
    I'm 58 years old and a pool rookie. Can't believe how much help this forum has been. Between the responses to my questions my own searches through community threads for answers. You guys have given me the confidence to know that this old dog CAN learn new tricks. Keep up the good work and thanks again.
    P.S.: I was directed to read the information provided in Pool School and keep within the parameters. That's all I did. No other help and I have been successful so far.....Read and Follow all directions...pretty simple, pretty wise. Thanks to all
    Bob (AKA Schnozz)
    38,428
    Sounds like you are off to a great start!!!
