Thread: Electrical Question
    Jaimee's Avatar
    Jun 2014
    Queen Creek /Arizona
    42
    Electrical Question
    I'm doing all the electrical myself and I've already installed the sub panel, conduit, feeder wires and conduit for pool lights, switches, outlet. I set an Intermatic T4000RT control panel and will be using manual switches. This panel has a built in transformer (to 12 volt) for the pool lights. My question is can I hook the GFCI breaker for this transformer to a time switch first and then to the transformer or is that not a good idea? I don't have to use the timers (2 fit in the panel) for the pumps because the pumps will already have timers on them. I hope this all makes sense. Thanks for any imput and don't crucify me please, Haha.
    Building
    4.5K gal in-ground, 876 gal spa in-ground
    negative edge, raised perimeter, 4' depth
    limestone coping, fine pebble plaster with abalone shell, sand filter, propane heater
    My pool build thread: 91265-Jaimee-s-Owner-Builder-Pool-AZ
    Jaimee's Avatar
    Jun 2014
    42
    Re: Electrical Question
    Latest picture of project. Plumbing and rough electrical is done.Pool ready for steel.jpg
    Building
    22,539
    Yes you can hook a timer between the breaker and the transformer. In fact, that's how you should do it.
    Jaimee's Avatar
    Jun 2014
    42
    Thank you, Dave. I've really been stressing this one. You helped me out tremendously.
    Building
