Results 1 to 10 of 10
Thread: That sinking feeling... Should I start over with another contractor?
    Mar 2015
    Liberty/Tx
    48
    Ok now I'm really concerned. I'm not sure if I should fire this crew, cut my losses and hire someone else. I'm really concerned with the baseplates. They used really small pavers to save money and raised and lowered them with sand. They didn't sink the pavers into the ground so that the rails sat on the undisturbed ground. They basically shoved sand under them. Am I doomed on this or can this installation work? They told me they install 80 pools a year in this area and a local AGP company uses them exclusively. Help!!!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    Re: That sinking feeling... Should I start over with another contractor?
    Sorry but you already know the answer They are NOT doing it right...............time to move them down the road
    Kim
    Casey's Avatar
    SW PA
    10,461
    Ranchdip~ have you thought about trying the install on your own and taking control? This is what I would do.
    Mar 2015
    Liberty/Tx
    48
    I wouldn't mind doing it myself but unfortunately I don't have any help or time. The pool will be counter-sunk and rain is in the forecast in 4 days.
    Saltwater 8000 30ft round AGP / 22,000 gal / 1Hp Hayward variable speed super pump / Hayward 150sqft cartridge filter / Hayward Aquarite 25k gal salt system / katchakid
    Mar 2015
    Liberty/Tx
    48
    I need some help guys. They are coming back tomorrow to fix it. I really need advise. The pool is counter-sunk 26" and the ground is hard clay at that depth. It's very very hard to work with. If they can get the pavers sitting on the clay will that be a viable solution? I was going to get the installers to start at the lowest elevation at the clay base and dig out the perimeter of the pool from there. This would assure that all pavers and rail would be supported by the clay base. Since this clay is almost impossible to get level I thought maybe we could get the pavers level and then tamp the bank sand around the pavers so the rails would have a smooth surface to sit on. Your thoughts? As you can see in the pic they raised the paver levels with sand which is unacceptable. And they are using pavers cut in half which are barely big enough to fit the column base.
    Casey's Avatar
    SW PA
    10,461
    Why are they cheaping out like that?! They need to start at the lowest point. Bottom line.
    Jul 2012
    Tallahassee, FL
    30,672
    They need to use oversized pavers so there is wiggle room as things shift.
    Working with clay is hard and can cause problems but ................it must be done for a safe pool.
    Good luck.
    Kim
    Mar 2015
    Liberty/Tx
    48
    Yeah. I bought 12" pavers for them to use
    Mar 2015
    Liberty/Tx
    48
    Thanks for looking and the help
    Jul 2012
    Tallahassee, FL
    30,672
    Good luck and let us know how it goes.
    Kim
