Thread: Short in my Intellichlor IC40
    My IC40 has a short in it and pops the breaker for in my easytouch station. I tested a replacement IC40 and it works fine, so my question is what could cause the short in the salt cell? The fins don't appear to have any scale on them or corrosion. Is it dead and useless now or can I resurrect it for a backup unit?
    mas985's Avatar
    Pleasanton, CA
    11,743
    Re: Short in my Intellichlor IC40
    How do you know the short is in the cell and not the control unit? It could be the main transformer that has shorted since a short in the secondary circuit would probably not trip the breaker.
    Mark
    Quote Originally Posted by mas985 View Post
    I would reset the break an within 30 seconds the breaker would trip. When I unplugged the IC40 the breaker would not trip for a day. I swapped out the IC40 and the breaker has not tripped for 2 days now.
    mas985's Avatar
    Pleasanton, CA
    11,743
    OK, yes it does sound like a bad cell. Visually inspect the cell plates and make sure there is nothing lodged between the plates. Otherwise, it could be a problem with the wiring.
    Mark
